1 - 3 of 3 Posts
Is 1/2 inch cold rolled steel thick enough to make a sissybar? This wouldnt come more then 3 inches off the fender but is it strong enough to possibly hold someone sitting on the fender without bending?
Also (rigid harley) how much ground clearance do you have? I know the springs in my front end arent compressed all the way but ive got at least 5 1/2 inches between the ground and my frame. Is this about average with no stretch or rake? (the frontends about 3 inches over) .
1/2" should be fine, that's what my sissybar is made out of. I would use 5/8" if you have some available though, especially if you will regularly have someone on the fender.
Most of my bikes have around 4" of ground clearance and they are fine, so 5 1/2" should be plenty.
Thanks. Dont really plan on having to many people on it concidering where im puting the pipes. But just makeing sure if i did the thing would support them .
I wondered about the ground clearance because it looks so high I thought the kickstand wouldnt be long enough. (dont have it yet so i cant be sure)
1 - 3 of 3 Posts
