Using the attached picture, could you all help me label some of these nipples?!
My oil tank has 2 inlets and outlet.
I believe #5 is the motor's outlet, which connects to one of the oil tank's inlets.
I believe #6 is the motor's breather, which connects to the other oil tank inlet.
I believe #7 in the motor's inlet, which connects to the oil tank's outlet.
I have plugged #2, #3, #4, and #8.
The big question is #1. Someone told me it was the "crank case vent". If so, where do I run the line to?
Thanks in advance for any help!
