First off I want to say I’ve fallen off the JJ for a few years, so please go easy on me with this bonehead issue and crawling back asking for help!
Some background on the bike and issue at hand.
A friend had this thing dropped off at my shop, he bought it sight unseen and it was touted as a “stroker” chopper professionally built and ready to roll. While it has descent parts, It had all sorts of problems that I could tell know one had done shake down miles on the skoot. Little stuff with the electrical, suicide shift set up and clutch adjustment. Squared a bunch of stuff away, got it starting on the first kick and was getting close to taking it on its maiden voyage. My pal, in all his infinite wisdom took it for a weekend and blew the head gaskets. I figured the engine had just been rebuilt and after heat cycles never retorqued the head bolts.I could roll the motor over with my hand, it had zero compression and I could see the gasket coming out in between the head and cylinder. I tore it down, did the head gaskets, inspected the valve train and had a look at the cylinders, pistons and rings. All of which appeared to have little to no miles on them and recently rebuilt.
After doing the head gaskets I put it together and, to my shagrin it still had only 20psi on the compression gauge.
It has rivera taper lite adjustable rods and hydraulic lifters. During valve train adjustments I would go to zero lash on the base circle, then per rivera adjust the rods out the 4-5 full turns. All lifters would bleed down and allow me to move on except the rear intake. The lifter wouldn’t bleed down even after a full day sitting, so I couldn’t rotate the engine over for fear of valve to piston contact.
So, apart again. Heads hold water in the combustion chamber when tested so it leads me to believe they are seating just fine.
Could he have blown the rings as well when he popped the head gaskets? I know I should have done a leak down test but it just didn’t happen.
