1 - 9 of 9 Posts
Went to order a Rivera Pro Clutch for an early big twin '36-'84 and the custom chrome book states, "Application is for chain primary". I've got 1 1/2" open belt so wtf? I was thinking this should work, but, you never know. Is the only difference wet/dry? Do I need something "special"? Any help? Thanks again, Ken
Discussion Starter · #2 ·
If you didn't see my earlier post, I've got a cone shovel, ratchet top 4 spd w/ jockey shift/foot clutch.
So do I except I have a 3" belt but that shouldn't matter. Order just the clutch it will use your old clutch shell.The clutch comes with it's own hub which runs on a sealed bearing, which is 1 reason it functions so well.
See, that's what you get for looking in CCI's catalog. What they mean (in a round about way) is that you'll be using your OEM clutch basket with the Pro Clutch kit.
The Rivera Pro Clutch part # PC-1000-A fits both the OEM-type chain drive clutch basket, and any belt drive setup that uses an OEM-type clutch hub. What you get is a big double row sealed bearing that replaces the OEM ball/cage bearing, and it also replaces the long roller-type bearings like the "Big Fix" bearings.
So, you need to reuse your old clutch basket, and the Pro Clutch kit goes into that, and they supply a new clutch hub. Call Rivera-Primo and order it.
Is this CCI part # 25106? I don't have the book in front of me. I'm still getting the COMPLETE kit right?
I get can get shop price out of custom chrome. Thanks fellas.
Yeah, CCI part 25106, as long as your present belt drive clutch basket is the the early style with the dogs for the plates in it.
You aren't getting a new basket in this kit, just the hub bearing, the hub, plates, and the diaphram spring/related hardware.
Discussion Starter · #9 ·
Yeah, got the dogs. Thank you sirs. Ken
1 - 9 of 9 Posts
