Big twin cups fit any post '57 Servi frame that originally came with a wideglide as the head casting is different than earlier ones. All '58 and later Servi-Cars used 1" stems. All Pre'58 Servi-Car and '52 and earlier 45 are 7/8ths with Springers. My mistake was assuming he had a frame for a wideglide Servi, which I do not know to be true. Your mistake is claiming all are 7/8ths!Big twin cups will not work on 45 or servi .They are 7/8 in stem Big twin is 1 in.They make a kit to run 7/8 stem on a big twin.But to go the other way 1 in to 7/8 in .You can turn down the male end of a Big twin cup to fit 45 servi frame and run the BT cups.
iiggii,Also remember Bt neck is 5 1/2 in and the servi and 45 are 5 in neck length.
I was speaking of older springer frames. But seems you know all .For this iam sorry.iiggii,
The '58 and later Servi-Car neck casting is the same length as a BT frame and the stem on a servi-Car fixed rake glide is the same as BT. Stem length is not an issue on'58 and later Servi-Cars with wide glides.
And I also have been sort of paying attention to Scavenger's questions so pretty much had a head start on answering his initial question!
Robbie
Bummer for you. I never am sorry for anything, even if I'm wrong. It just means I learned something. No reason to be sorry for that! But some folks just choose to be martyrs!!.For this iam sorry.![]()
Stop it you are scarin me..Bummer for you. I never am sorry for anything, even if I'm wrong. It just means I learned something. No reason to be sorry for that! But some folks just choose to be martyrs!!
Robbie
Measured 2 trike frames they have a 5" neckAlso remember Bt neck is 5 1/2 in and the servi and 45 are 5 in neck length.
WRONG !,,wasted $ and can't even use emSame as BT, just be sure you use early ones for tins and late ones for nacelle. If you aren't running that stuff either will work.
Robbie
You claimed you had a '60 frame. That would use BigTwin cups. Perhaps your frame is not what you think it is? Do you even know what you have?? I can't help it if you don't have a clue. And don't expect any more help from me!WRONG !,,wasted $ and can't even use em
anybody got a set of WG cups for a servi-car ??
