I did a little searching but I got some conflicting info, so maybe a few people can school me on the ways to ID the years, steering stem sizes by year and when they changed from manual brake to hydraulic.
So far I've heard:
* 1951 as the first year for hydraulic brakes
* 1958 as the first year for 1" stem
Info provided by Dragstew and Scavenger
37-40 2 bolt tranny mount
41-47 3 bolt tranny and 2 bolt clutch cable mount
48-50 3 hole clutch cable mount
51-57 Hyd brake mount 7/8 neck ( look under neck for seat for springer damper )
58-73 ( 74 ) Same as above but Glide neck, 73/74 has a bracket on the right side for E brake handle
As introduced,(1932) the Servi-Car had a drum brake on the front wheel and another drum brake inside the rear axle housing, decelerating both rear wheels. In 1937, the braking system was upgraded to have a drum brake on each wheel. A hydraulic rear brake system was introduced in 1951. The very last Servi-Cars, built late in their last model year, would have disc brakes on all three wheels.
The early (32-36 ) rears are HUGE in the middle, so easy to spot. The disc brake model was also 6 lug.
Am I wrong? Any way to correctly figure the year of a Servi frame?
Thanks everyone.
So far I've heard:
Thanks everyone.
