I probably already know the answer to this, but I thought I should double check.
What do you guys run for fitting sealer (if anything)? Brass on brass? Brass on aluminum? Brass on stainless? Straight and tapered pipe threads? Brake lines? Oil lines? Petcocks?
Obviously teflon tape is not going to work out here (especially on petcocks)... so what's good to use?
