have an old super b I am rebuilding and have some questions...how do you get the throttle valve off the shaft?? does the shaft just slide out after the screws are removed?? mine seems stuck pretty good so I am gonna soak it in some wd40 for a couple days???
Discussion Starter · #2 ·
okay, lets forget I asked that question, went back and looked at it last and the answer became very obvious. Next question though, I lightly sanded the gasket surface on the float bowl to true it up, the carb body gasket surface I cant because of the enricher tube and main jet housing, how can I true that up?? I can see daylight between the float bowl and carb body in one spot??
