A word on the S&S breather gear....
It has a few up-grades to it....
One is ....
More window timing built in....
The Oem gears would be in need of sawing the case window to add open timing to maximize breather efficiency....
I would be asking why this need to be done....
Harley didn't do it....Right..??
Here's why...
Improper breather timing causes poor oil scavenging from flywheel cavity and incorrect air pressure.
These conditions may cause unwarranted engine oil leaks around gaskets and seals and probable oil burning due to oil blow by past piston rings.
Two.....
Breather oil trap scavenging is significantly improved by increased scavenge port duration.
These improvements are the result of exhaustive research using digital sampling and data acquisition equipment by S&S engineers...
If you wanted to do a little work....
You can mod. the OEM gear to the S&S specks....
The one on the right is an S&S with the screen removed for adding a air ramp to it..
On the left is a Stock one that was mod. on the pull back port....
And set up a degree wheel to dial in the open and closing timing of the case window....
