1 - 4 of 4 Posts
CityRichmond
StateVA
Price$500
A nice clean S&S MGL Carb with the accelerator pump mod. Bowl is clean and corrosion free but is drilled so you can insert a fitting (or plug it if you dont want to use the pump) to provide fuel to the accelerator pump that is attached with brackets to the bottom of the carb. Comes with the manifold and everything you see in the photos. $475 shipped (with insurance) to your door in the lower 48. More if you live somewhere else so message me first.
Yes this is the late model (L) of the early S&S carbs. I'm pretty sure the pump is a Mikuni and this was a fairly popular modification to these carbs. Some used Thunderjets instead of an accelerator pump but this makes it the same as a modern carb. You can check this thread for more info. It's not exactly the same but the same general principle.
1 - 4 of 4 Posts
