Take off the air cleaner and look while you move the lever and I bet you answer your own question...
Hey Holy,Thanks appreciate it, now all i have to do is figure out the best kick start sequence
Hi no offence taken, that was actually one of the very first posts that i read, the starting sequence was more rhetorical as i've had success in the cold weather in varying temps with different combos.Now try an intro and using the search function on here...since I have been accused (likely rightfully) of being an asshole, here's one link on here that answers that. For the rest of your questions, please do us all a favor and try to find it yourself first because it's probably already been covered a dozen times.
http://www.jockeyjournal.com/forum/showthread.php?t=16074
Hi Monte,Hey Holy,
Remember that you are relying on the Vacuum of the motor to draw in fuel mixture, I have an 1 3/4" GBL on my 69 XLCH with a Magneto, I never even consider trying to cold start until I go thru my ritual
1) Full Choke, Petcock Open
2) Wide Open Throttle
3) Thumb on the kill button
4) 3 to 4 kicks to prime
5) open choke or 1/4 open in cold weather
6) thumb off the Kill
7) throttle closed or just off the stop partly open
8) On the Compression stroke you kick all the way thru (my bike has manual retard that helps)
* These are classic carbs that are now part of S&S history, this was the invention of George Smith Sr and with the help of Drag Racer Leo Payne, these carbs became a reality... every bike has it's own personality add to it the timming on each can be a bit off or spot on..
Good Luck
GBL #533
Monte
NOT!! Any 'L' Series Carb is Extremly Cool, they stopped making them in the late 70s but I know what you meant, to clarify the GBL @ 1 3/4" was the smaller throat carb that better suited a stock 900cc or stock shovelhead, the GAL, MGAL, MG were all 1 7/8" throat, Mr George Smith Sr. must have been a Very Smart Man as the GBL was designed right at the Time Harley riders were bitching about the Tillotson Carb that was a PITA to keep tuned... I have a Magneto on my 69 CH with the GBL,(on par with a John Deere Tractor) I am building a bike now that will be 75" and will run a MGAL, also think of these carbs as a 'roll open throttle' carb meaning that is does not always have that snappy wack open response as a carb with an accelorator pump but once you get moving hold on to a very strong midrange and top end, I agree Holy that the L carb is the best looking Carb ever installed on a HarleyMonte,
thanks for the advice, i've got the mgal myself, definitely not as cool or rare as your gbl tho, i'm hoping it will perform well for me as i love the look of it. Is your bike running on point or electronic ignition.
Been pondering putting in an ultima single fire EI this month
Actually, it doesn't take an absolute genius to scale up a DC linkert by 30% or so. Not to take anything away from Geo Smith or Leo Payne or any of those guys. Definitely a cool carb though. I'm running a GBL on my 74" pan. It's really cool if you reverse engineer the carb sequence you can see how they got to the MGAL (M74B -> DC Linkert -> DC linkert with the 9X butterfly -> MG -> MGBL -> MGAL. Of course, there was an FAL too which had jets that look like soda straws in it.Mr George Smith Sr. must have been a Very Smart Man as the GBL was designed right at the Time Harley riders were bitching about the Tillotson Carb that was a PITA to keep tuned...
I'll agree, albeit conditionally. To their credit, the S&S L-series was never intended for the street. Would you care to quantify your statement? Which do you run?Hi all, I love the side bowl S&S carbs...but still think the DC Linkert is a better street proposition!!! Patrick
Not to Speak For Patrick but it was Lessons Learned from Drag Racers that led Smith and Leo Payne to design the L (from what I have learned) right here in New Jersey a Racer and Machinist from years back by the name of Maynard Price - Custom Cycle Engineering - Paterson NJ use to Bore Out DC Linkerts and machine Bowl Spacers for more gas capacity and this story came from a phone call with Vito Sabato that just in October 11 had a gas Ironhead that went into the high 8's.. Mayne did the case machining on my XLCH 25 years ago and was a Humble but Super Talented Man..I'll agree, albeit conditionally. To their credit, the S&S L-series was never intended for the street. Would you care to quantify your statement? Which do you run?
