1 - 12 of 12 Posts
Whats going on ? got a 74ci shovelhead with n super e on it. Got the .295 & .72 jet installed. Bike seems to be running pretty good, but plugs stilll indicate alittle richness..What would be recommended as far as jetting or just lean it out from the carb ? Starts failry easy and took it out no coughing popping or stumbling...
So what's the problem? Shovels like it a little fat. You could try the next smaller size main and see if it leans it out some but it seems you have the right combo.
What kinda pipes? Muffled? Baffled?
I have an 80" Pan with baffled straight pipes....Im still a bit fat with a .028 intermed/.070 main at 1-1/4 turns with Accel pump turned off completely.
Im thinking .072main might be a little fat for you. Hows the throttle response above 45mph?
· Premium Member
Look for my post on modifying the super E, if you cant find them P.M. me and I will explain, your accell pump is sending a false idel circut and making it look rich.....Roach.
1 - 12 of 12 Posts
