1 - 14 of 14 Posts
leadsled said:
Have you considered a washable (K&N). You will have to look at your jetting. Although I notice the drag pipes. You may be all set. tim
I hear this isnt the place to talk about such simple things as air filters but yea. my STOCK set up has a K&N now so I am all set.
got a part number?
hey nads, spend a few bux more & get the k&n filter. it will last a lifetime & keep your motor much cleaner. plus, when you sell the bike, keep the filter! i have one that has been in 4 or 5 different bikes over the years, i just keep putting s&s carbs on them!
heres a dumb question. Do I have to have S&S carbs to run this cleaner? Nads said I didnt?
Im calling the chopa shop at this rate ahah
I don't have an S&S cleaner on my bike anymore. I never even had an S&S carb, although I did try a SuperB when I first built my bike, I couldn't get the bitch to run right at all, probably because I'm an idjit.
I've had a Khiein on it forever, even when it was a 96" stroker.
It's been a real good carb, but every few years the overflow tube cracks and gas goes spilling out the carb.
Mike no you don't, the mounting plate holes ought to match up.
I'm thinking your bike also has a breather that goes to the filter, you might have to drill a hole in the filter housing to accept the hose.
Do you have a Keiein carb on your bike?
Discussion Starter · #9 ·
hahaha you looked at it and said I do! hmmmmmmmmmmm you are old short term M Fer.
I didnt see any tubes either. Ill find a filter and see what happens from there
Bollocks dude, I said the cleaner housing WILL fit, the mounting holes on S&S carbs are the same as most HD CV carbs.
Couldn't tell you about modern F.I and such.
1 - 14 of 14 Posts
