OK, back is feeling better and lots of parts have come in. Decided to get the front end all buttoned up. The TLS front setup that I bought cascaded the need for a whole bunch of other parts since it's about 1/4" wider - so I needed newer upper and lower triple trees. I also decided that the fork tubes were too far gone and installed a new set. I was able to get the bunged up fork slider threads sorted out myself with a small needle file, a loupe and some patience. My machinist was just too busy and I'd rather have him spend time machining my seat spring cups.
Anyway, I seated the fork seals in the dust sleeves with a big ol 34mm socket. No problems...
I also added an extra black plastic spacer on each fork tube, cut down the springs an inch and a half, heated, bent and ground down the ends for a flat surface, bead blasted, primed and painted them up.
Turned out pretty great I think. Shown here during a test fit...
I also needed to fit the TT style upper fork covers. Comparing them with the stock elephant ears it's easy to see that the TT's are longer by about a half inch or so below the tabs that the lower tree bolts through (marked in blue tape)...
So I put a cutoff wheel in the dremel and lopped the extra off, filed the bottom perfectly flat and chamfered the edges slightly. I also needed to elongate the mounting tab bolt hole so the bolt wouldn't catch but just slightly. Here's a shot of the finished TT cover...
And below are a couple of shots of the whole fork assembly put together. The lower members and trees have yet to be powder coated black. I'm going to leave the dust sleeves stainless. Basically, everything will be black except the tube itself and dust sleeves...
Oh and my custom spoke order from Buchanans showed up today so I can finally drop everything off to be laced, trued, tires mounted, etc. More on that next time.
Have a great 4th everyone!
