1 - 11 of 11 Posts
TI_Tuesday
I have a reproduction BT springer and a new style wheel with 3/4 axle(no brakes). what axle setup are you guys using with late model (3/4 axle) wheels? Are you drilling out the left rocker and sleeving the right or maybe even replacing them with 45 rockers? maybe I'm going at this wrong but figured I'd ask before I butcher something. thanks in advance.
sorry if this has been covered before, I couldn't find it.
Are your rockers 5/8 if so just go to Bearings Inc. or same kinda of similar company and replace the 3/4 bearings with 5/8 should be a simple swap.I think Teach on here had some kinda post about this awhile back.You would lalso have to make a center shim to go between the bearings to set the preload on them.Hope this helps.I think this should be able to be done with out alot of fabrication and building.
Shoe
TI_Tuesday
thanks.
I got the spacer thing covered and have a small lathe so should be able to turn the axle down a bit. Hey Trent, what did you make the axle out of? specifically, if you made it from roundbar what material did you use and on the non-threaded end as a nut/stop? I guess you could weld a big nut to solid stock and thread the other end after turning it down a bit...may not look real good though.
Atomic Custom
tom said:
thanks.
I made a shouldered cap and tig'd it on.
TI_Tuesday
Discussion Starter · #8 ·
or thread both ands and put a nut on each?
TI_Tuesday
Discussion Starter · #10 ·
you elitist TIG fockers! all precise and shit. I'm gonna nig something...should be ugly as a mofo.
1 - 11 of 11 Posts
