I've found a set of replacement shovelhead alternator/cone cases from the HD factory still in the box... But, noticed something that had me ???- The replacement cases have the numbers are stamped on the left side...
My original '81 shovel motor has the numbers stamped on the right side (cone side).
Any ideas as to why the factory numbers would have been stamped on the left like the older pan-shove models?
If it helps the engine numbers start with a AKKB (K = 80') (B = '81) not sure about the AK
