Is it feasible to repair pan cases that crack around the cam bushing hole? I came across a right side 51 case with 3 cracks, one going out around 3:00 then upwards, one at 5:00 down to the bearing race, and one at about 10:00 that goes out and upwards an inch or so (it doesnt show well in the picture). The cracks show on both sides of the case, I couldnt get the flywheel side image to show the cracks.
The intended use is for a franken motor, the right generator case on my 84 shovel 80". I dont hot rod, but its going to be a sidecar rig and expect to dirt road it and as much pavement riding as I can with a bum back. I understand the 58 and later right case has larger bearings, but I havent come across a 58-69 right case. am I asking for trouble using the older type case for such use, or asking for trouble to use a repaired case for such use?
Who can do the machine work to get the cam bushing back to spec after welding? I have a good welder, but nobody to do the machine work after welding.
