1 - 16 of 16 Posts
I have a tech question....
I didn't see a thread on it but...
What is the proper way to remove a harley forged neck on say a VL frame? If want to maintain the tubes and forgings? Probably sounds like a dumb question.
I had a cut off neck from a mid 70's Sportster years ago and I had to remove the 2 lower tubes and the backbone to use it on a project. The amount of heat and force it took to get those tubes out was amazing. We had to heat the head up cherry red and use a pipe wrench with a cheater bar just to get the tubes to spin in their bores while we melted the Bronze(?) out of the casting.
Like El Diablo said and judging by experience, you're gonna ruin either the casting or the tubes getting it off.
There really is no "proper" way. The frame was assembled in a jig and all the the forged or cast steel fittings and tubes were then brazed as a unit. If your trying to save the neck casting / forging, saw the tubes and "unbraze" the remaining stubs from the sockets.
Bob
Discussion Starter · #8 ·
Yes the forged neck. I was hoping there was a way to remove it while saving all the components. Sounds like chopping and running an endmill or drill to clear it out. I was hoping that the brazing could be removed and it would all come apart nicely without damaging anything. Thanks all
I´ve done of couple of separations,- impossible to save the tubes. A lot of them are pinned through the castings, as well. Cut and mill!
If modding´s your game, cut the tubes some distance from the casting, do what you have to do and weld the whole thing back together with inner slugs.
Mads
I would tack weld some flat stock to the tubes about 6 inches behind the neck to hold the shape of the frame, than cut the tubes an inch from the neck. Heat up the neck with a rosebud torch remove the tubes. Turn up some slugs on your lathe to fit the ID of the frame tubes press fit them into the tube and rosette weld them. Fit new peices of tubing to desired length and weld around the outside.
Mads
You're gonna get metal shavings in your beer.
Discussion Starter · #15 ·
Your friend wants you to attempt to knock an OEM frame down to save a few bucks shipping??? Why doesn't he just buy repro castings there and build a frame?
It has had tabs removed and some work on it already. He got it for 800 I think a re-pop is probably more, maybe not though. Last I saw a forged neck was running 4-5 hundered, axle plates about 150, I don't even want to know what the trans and motor forging costs.
1 - 16 of 16 Posts
