Those here that may remember me know that I go to obsessive lengths to make old equipment work better.
I have spent years messing around with HD juice drum brakes to keep my alive in NYC on old machines.
Some things I learned that may be helpful:
- Change out the rubber hoses for hard lines or quality braided hoses to give up less energy to flex. At very least, change out with quality new rubber hoses.
- Most repop brake liners commonly available are too hard and don't offer enough friction to be effective for the surface area and force used in this application. Buy soft liners from a brake and friction shop.
- Alter your brake pedal or make your own with more mechanical advantage to get more force in the system. Moving the link 1/4" will make a difference.
- Indicate the brake drum surface (you can buy a POS dial that is accurate enough for this purpose for $20. No excused. Valuable tool) to ensure concentricity. Any out-of-round or eccentric conditions will rob energy. You can rotate the drums on the hub by one lug and retest until you find the best spot. Mark the drum and hub so you'll remember this position. If you still have runout, get the drums cut.
- Spend time setting the depth of the shoes in the drum correctly. With so many bikes (mine included) being mix of year groups and parts families, sometime the various spacers will have the shoe service not fully in the drum.
- Find an oem set of brake shoes (even if the liners are shot). The metal is thicker, stiffer, higher quality. This provide more uniform pressure at all point of the brake liner. The repop ones have too much flex.
- arching the shoes is a real thing that yields immediate results. Any shop that hasn't heard of it knows nothing about drum brake systems. Ask a brake and friction shop about how important it is and if the do it (they do).
- arching the shoes yourself is a short easy job. Here's a
video of me doing mine the last time I did a rear tire change on my '58.
- clean and adjust all pivot/slide/rotation points from the lever back to the drum. Why use force overcoming linkage friction?
That's it for me. Have fun.
Jason
