Did a search & didn't find anything, thought it might be interesting to see what you guys have used for brake rod adjusters.
Got the idea after my Triumph adjuster stripped out, & I needed a quick fix.
I had a flow adjuster "T" bolt from an old oxy / acetylene regulator that worked perfectly. being brass, it was easy to work with.
I drilled out the center, tapped it with 1/4" x 28 and cut the seat part into a "cup" so it won't back off like the orig.
Never had an old Harley, but I'm guessing the application is similar.
Rick
Rick
