Yup, my old man just did one.
Out of curiosity, what would this have to do with the gear set?Yep, that 77-85, the break was 76 as the last right shift with the crossover linkages, the 77-84 were left shift only
Word. Now castle top, thats a new one to me. Cow pie, cow pattie, rotory top, all those but not castle. I can dig it.^^generally 4 sp means BT....79 =castle top....theres no pics so Id thought you was right...cross over? now thats sporty
On occasion I hear them called maytags. I guess someone thinks they look like a washing machine top.Word. Now castle top, thats a new one to me. Cow pie, cow pattie, rotory top, all those but not castle. I can dig it.
I think, that if replaced as an assembly, any sportster four speed will fit into any sportster case. The shift linkage doesn't matter, as it engages the pawl assembly in the same way. When I say four speed I guess I mean IH.Yep, that 77-85, the break was 76 as the last right shift with the crossover linkages, the 77-84 were left shift only
Well, yes, BUT, the shifter plate shaft, is longer on the rh shift pawl assy, and you have to either change it, or get creative to make it fit a lh shift motor. I have also noticed some small differences in the trap door, on the bottom of the door. The newer transmissions will bolt right into a older bike, but the older transmissions are a little more time consuming.I think, that if replaced as an assembly, any sportster four speed will fit into any sportster case. The shift linkage doesn't matter, as it engages the pawl assembly in the same way. When I say four speed I guess I mean IH.
