1 - 3 of 3 Posts
Questions about 1st oil change on a Rev-Tech 5 in a 4 /w kick
I'm about to do the transmission break in oil change at 1000 miles and I have a few questions. It's a RevTech 5 in a 4 with kicker.
First off, the RevTech warrenty card says to use 80w-90. I went to a few dealerships and indys today and all I could find was straight 90, HD brand tranny fluid(that doesn't specify the weight), and Bel-Ray 85w-140. I guess I could use the 80w-90 that I have around for my car. I found this thread but it's for a HD 4 speed. http://www.jockeyjournal.com/forum/showthread.php?t=4282S. Should I keep looking for motorcycle 80w-90(Bel-Ray?) or is 85w-140 okay?
Also. I want to make sure I unscrew the drain plug. On the underside of the transmission, there's a small allen head that's diagonal- compared to the rest of the allen heads that hold the case together. Is that the drain plug? I't looks really small diameter and I want to make sure I'm unbolting the right thing.
Thanks,
Jim
Thanks,
Jim
How bout I just sell you 2 qts Rev Tech tranny lube...??? Manufacturer has their own requirement for a reason...if interested just drop me a PM...later Chaz
Thanks for the offer. But I finally found 80w90 Bel-Ray Gear Saver at the local Kawasaki dealership.
Now for some other questions:
  • How much trans oil does it take? There's no dipstick that I can find.
  • Where's the drain plug? The only thing that looks like it could be a drain plug seems too small.
Sorry for all the beginner questions... but, well, I'm a beginner with this transmission. And I can't find a Rev-Tech service manual (although I did just order the new S&S 96" Evo service manual that just came out).
Thanks,
Jim
1 - 3 of 3 Posts
