I'm going to turn down a brake stay out of aluminum to weld to a 39mm fork bottom to fit an early sportster/fx drum brake (the ones that came on the 33.4mm front ends). I was looking to get some 6061 to do this, will that be except able as far as strength and weldability to the alloy in the lowers? I was thinking it would be ok as the direction of force pushes the stay into the back of the leg. Any other tips on doing this would be appreciated I'm fairly decent with the tig on metal but a novice when it comes to alloys like, which tungsten or filler to use to practice. I have some 5356 rod would that work? Thanks
