Ok, so with sage advice found in this forum, I was able to figure out my transmission issue- Shift pattern was opposite of what I thought (thanks Search and Destroy). I've started it several times to find out I really should turn the fuel on first. With many archive inquiries in this forum, as well as several others, I've figured out the right plug, wire and gap to run with my magneto. The next thing left is a fool-proof kick method. It kicks back something fierce but not always. When it actually fires up, it's a smooth low kick that does it. Are the kick backs from me not timing the kick correctly? How do I know where TDC compression stroke on front cylinder is (if front or back matters)? Should I be 30+ degrees before TDC when I start the kick? Back of my knee was more than a little inflamed from the last leg wrestling match. I would like to end up with a legit 2-3 kick Pan/Shovel. Oh yeah, carb is a Super B w/superbowl, I don't believe mag has manual retard- likely a Hunt. Just put the non-resistor plugs in (J12yC Champions, I know most go with Autolite 75's or other preference) these are new and gapped at .019- tomorrow morning I'll do battle with it again...still have not ridden bike under its' own power
