Why? Nothing there a little Kreem won't fix.
Just kidding, I'll be following along on this one.
Will be soldered.will you build it to look the part using more modern methods or brazed, maybe silver soldered oem joints?
did a copy of some 1915 tanks once, had these as a pattern...
and that turned into...
and then...
lessons learned... don't tack weld with a mig, use a tig if welding.
these turned out close but not a perfect copy of oem...
i must first say, i am no pro at working sheet metal.
Hey Dan
Hey Richbob,Is the tank going to be bigger ?
As your using original as a buck
