1 - 12 of 12 Posts
Has this happened to anyone? I got some grindage sound right before I was going to get some gas, then no more accelleration, dropped the primary case to find that all the teeth had stripped off the pulley, the mainshaft nut was still tight. new EVO with 5 speed. It was like have a doughnut for a beltdrive front pulley. I just what to know what might have caused it.
tranny dry?? might be some resistence there causing the front sprocket to wear...how many miles on the tranny?? decent belt drive that isn't hammered should dam near last forever...I would start at your tranny especially after hearing it grind although that was probably due to the front pulley teeth disappearing on ya...
I don't think I ever locked up the rear or the tranny when engaging it. Though I do have a slight leak. I'll check on that next. I just want to prevent this from happening again. I see what your saying about the tranny reating reistance.
Atomic Custom
I have seen them wear due to the motor nut being loose, but never strip completely.
What insert do you have? I have a few laying around, let me know what you need.
egads! I've seen worn teeth due to loose nuts, but never completely stripped like that without prior symptoms. Even if the trans locked or something, the splines shouldnt strip like that. I've beaten the hell out of those things with almost no wear evident. I'm gonna go with defective parts on this one.
pulley spline be gone for one reason... no clamp load from the nut.
look at the back side of the pulley. see the wear from the rotor washer?
measure the width of what's left of that pulley.
then measure the length of the spline on the sprocket shaft.
guessing here that the washer behind the nut (you did use a washer right?) bottomed before the pulley was champed tight.
Danny F. said:
No stripped teeth here...:D
No that just makes for other types of problems.
On the stripped pulley, I'd get it rockwell tested and see if it's a defective part that didn't get properly heat treated. I have never had that problem. Usually the belts fail due to heat, incorrect adjustment, or sand and crap getting into them.
1 - 12 of 12 Posts
