Hey ya'll,
I'm piecing together a British front end to run on my panhead for a change from the stock springer. I have a mixed bag of parts and no knowledge of anything British.
Basically I've got fork tubes and legs for the late 60's early 70's front ends. Steel legs. Along with the damper setup with aluminium shuttle valve. I also have a set of early pre-unit legs that I would like to use instead of the later legs. I also have earlier pre unit trees with the built in rake.
Does anyone happen to know if the later fork tubes + damper setup can work with the earlier pre-unit legs and trees? The tubes seem to fit nicely in the earlier lowers as well as the trees but haven't tried setting up the damper etc yet.
Thanks.
Thanks.
