After searching all the posts about polarizing your Generator after you disconnect the battery from the bike for any reason, this is what I believe to be the correct steps to re-polarize your system.
<O
</O
(Polarizing for dummies)
<O
</O
(1) Identify the Generator terminals: Next to the poles on your generator, there should be an "A"(armature) and the other one, should have an "F" (Field coils)
<O
</O
<O
</O
(2) With the engine NOT running and all the wires correctly hooked up to: (a) the regulator (b) generator and (c) the <ST1
Battery</ST1
. Connect one end of a jumper wire to the generator armature (A) terminal. Momentarily touch the other end of the jumper wire to the positive terminal of the battery. This restores the magnetism. Remove jumper"
<O
</O
<O
</O
I just wanted all this in one post so its easy to find..
If any part of this is incorrect, please chime in!
<O
</O
KV
<O
<O
<O
<O
<O
<O
<O
KV
