1 - 13 of 13 Posts
my advice? ask Fabricator Kevin to make you a set....he made a set of round stock, turned, and fishmouthed to fit the frame perfect. well worth it if you dont have the tools to do it yourself.
http://www.fabkevin.com/seat kit.htm
if you have evertyhing, seat ,etc. im pretty sure you can just get these without the whole kit :) if not, let me know and i'll beat em into submission...
i made mine out of a piece of angle iron--welded to frame & used as rear fender mount as well as spring mount--cut a couple of bolts heads off so the shafts were at the right angle & welded them to the angle iron mount. put rubber shock bushings on under spring then tightened nut down--very solid & very cheap!! some pics in link---maybe you can see how they worked out.
frank
http://community.webshots.com/photo/446299780/446299780NvDVQX
1 - 13 of 13 Posts
