21 - 36 of 36 Posts
While i love the look of what your doing - we had rode this type machine every day and most of the night - the roads in NYC are and were like a mountain loose rock pass with street caves bent and bottomed it a 1000 times
hope your roads are a better deal my back and right ankle still hates me for it
Discussion Starter · #23 ·
John jzjz My back is already shot so the panhead won’t get a lot of miles
but I’m sure having a blast building it!
Slavedave your panhead chop is beautiful 😎
Dave that’s a memory - never forgot how simple they were and 55 years ago they were every place
  • Like
Reactions: SLAVEDAVE
You use less air in the tire just enough so it does not feel like its going flat - as the summer gets hotter it will increase in pressure like race tires - finding the happy spot will keep you on it more - when we were doing this the gas stations had free air so a pocket gage and some cruising on a nice day gets you real close
Discussion Starter · #27 ·
That’s why I took off the 18” rear wheel and low profile metzler going with 16” and 5.10 high profile tire and as you say air it down some
They tip close to 400 lbs
  • Like
Reactions: Ducbsa
Discussion Starter · #32 ·
Front forks back together with lower legs polished new seals & fresh oil
And new avon speedmaster tire
Your cheating showing off your talent in the great visual that the machine represents
  • Like
Reactions: Thebigguy0811
Discussion Starter · #34 ·
Thank you
Had a issue with rear wheel spokes not working with the 16” rim so my rear hub & rim are at Bucannon in socal they are making the spokes. Once I get the wheel back the pan will be a roller again😎
We run the air in the rear tire at the point of being flat and temp gun it to keep it from overheating
you back will thank you - Ben gay before you ride it helps also
  • Like
Discussion Starter · #36 ·
This link is a story about the local pin striper that painted my tins he’s a local Legend
21 - 36 of 36 Posts
