Citychico
Stateca.
Pricewithin
65 pan 3spd and reverse trans..pulled from a runner that was turned into a 2 wheeler again..65 date code on case and lid..shifts through the gears..case in nice shape no repairs anywhere that I can see..bolt in and go..$1000..
Short shaft joe hunt mag..just dis-assembled,blasted,clear coated..bearings cleaned and re-greased..new points,cond,and cap gasket..nice spark..plug it in and go..$425..
knuck or BT flat rocker clutch..nice given its age..a little pitting in the metal..clutch rod pivot on the back side wil need a little tlc..but easy fix..$125..
