Galaxie500XL said:
Here's another link from BCS.
http://www.britcycle.com/Products/ard_cdi_magneto.htm
Has anyone run one of these? Which would be better ARD or Joe Hunt. I'm thinking about getting one.
What's the down side on the mag other then no lights on the side of the road. I'm still waiting on a price on these things.
I am no expert on this CDI but I own an old flat track bike with one. When I purchased the bike this ignition came on it and I had no clue as to what it was. I was going to post pics on the board and see if anyone could tell me what they thought.
What I do know about the ignition is it works excellent on my T100 500cc and with the mikuni carbs the motor fires first kick everytime. I am planning on running the wires through the frame to clean everything up a bit. The ignition must be bulletproof as the bike has been laid down on the flat track, CDI side down, several times and it still works flawless.
I have the cyllinders and head pulled off getting reworked and a bore so I can not take a movie clip of how it runs. Since you are in Austin as well when I get the motor back from the machine shop you are welcome to come over and see it work in person. I included pics below.
P.S. You will have to drill a hole for the wire to feed out the back of the points area. My coil and other parts are mounted under the fiberglass tank. Hope this helps.
