I've got a dogs breakfast of a pan project and I just realized Ive got a problem with the compatibility of the oiling systems. Here's what I've got a 1951 Left case and a 1964 Right case with 1956 heads and aftermarket new jugs.
Having the '51 and '64 cases causes the flywheel assembly to even be custom built from one side to the other. This new problem has me a bit stumped.
I guess the easiest solution is to run outside oilers from a "Y" on the oil pump and then drill and tap the heads to accept lines. Does that seem like the easiest solution? Is there anything I'm missing? Will the oil returns work fine even though the path on the '51 case ends at the '64 case?
