1 - 14 of 14 Posts
Premium Member
No prob, if you want to you can run a oil filter and a cooler to increase the capasity, remeber that Air cooled bikes are allso Oil cooled....
I am considering building a tank as well and have the same questions... mine is an 80 ironhead, how much does the motor hold and what is the required capacity? Good idea on the filter... also where do i get the return line bung with the tube so that i can run the line to the bottom of the tank and make sure the oil enters the tank at the top... or is that a tube i need to make?
motor does not hold any to speak of, because it is a dry sump. the tank should have 3 quarts like roach said. and why not just weld your return and vent bungs at the top of the tank? no need for over complicated tubes and such.
Aesthetics I guess. If the lines come from the bottom it's a cleaner less cluttered look...gotta weld the bung anyway right? Saw a couple at the last swapmeet with the tube figured it's normal piece. Guess not?
Don't forget that piping adds capacity. Larger pipe ads more but flow slows down and can cause turbulence. Re( Reynolds value over 3k can be probable turbulence).
V=velocity of liquid
P(rho)= density of liquid
D= diameter of pipe
m(mu)= viscosity of liquid
Ideally the liquid flows best with laminar flow, and will have a parabolic flow pattern ( edges travel slower than middle) and the pump may get more work than designed for it by making the feed line to the oil cooler too big, but you may be able to add significant amounts of oil to the system and keep a smaller tank.
See I was going someplace with that.
Well mat, dat dar Expliens it to us dummys.. ;)
Yer Oil tank is dun and the basket, gas tanks next.....
Lol I just keep thinking about a very small oil tank with larger than normal lines for holding bulk. I was thinking about a 1.5 quart sized tank with lines & cooler holding the rest.
Prolly end up puking the oil out of the tank onto the floor :p
1 - 14 of 14 Posts
