1 - 4 of 4 Posts
I am trying to build an oil tank for my Triumph. I have been able to make the raw tank with the drain and fill plugs.
But now I have two quesitons:
1. Does the t-pipe have to be attached to the tank? I was thinking that it would be easier to just have a split in the oil line.
2. The cutout pictures I have seen of the tanks show the return line leading up through the bottom and I have heard some people mention a restrictor in the return line.
Can you have have the return line just feed in the top?
on a harley the vent line and the pump return line just dump in the top of the tank above the oil level. pretty sure a triumph does the same. tanks that have all the fittings on the bottom just use "stand pipes" that extend through the inside of the tank to a point above the oil level.
The return going into the bottom of the oil tank is a tube that runs to the top of the tank inside of it so it dumps out but it is a smaller line which causes a sort of back pressure causing the oil to move up the t-line into the top of the rockers. If you try and t the line without the restrictor you will get no oil up to your rockers. Its different than Harley stuff.
Answers 1 ) no: the rocker feed just needs to be plumbed in the return line
2) you will need to have restriction , use same size hole as in stock tank ( sorry cant remember what it is and my bike aint parked here so I cant check)
3) yes you can feed the return line into the top of the tank rather than going thru it .
Hope that helps
1 - 4 of 4 Posts
