Hey I recently got my 80ironhead running and I spilled some oil out of the tank last night. Which is ok but it smells like gasoline and seems a bit less viscous. What could be the reason?
Try removing the sparkplugs, then jack up the rear of the bike, put the transmission in second gear and rotate the rear wheel. You can magically turn the motor forward or even backward should you so desire.I obviously have had some fuel down the cylinders so a bit of oil down the hole should help rep seat? What kind of compression is optimum?
Stupid question of the day alert!! How do I hand crank? I can bump it over with electric start but aside from pulling the cam cover off is there a way to crank the motor?
