1 - 3 of 3 Posts
The part in question is #45 in 1st pic. It was pretty banged up. I reformed the lip, but not sure if I made it to small. Now im pretty sure the washer sits against the crank bearing, but is there supposed to be a space around the case? Or is it supposed to be a slight interference fit onto the case?
272471
272472
272473
It's just a bearing shield...supposed to just turn freely in the case and keep any broken pieces from entering the timing chest in case of bearing failure. I'd rather see them a little loose than actually contacting the crankcase. I wouldn't have any problem reusing that one...just curious, are you using std bearings, or superblend?
Great...thanks. The description of the part as lipped sealing washer had me thinking. They’re just the standard bearings.
1 - 3 of 3 Posts
