1 - 6 of 6 Posts
First post. Building a Nourish Triumph to run at El Mirage, but I have 5 other Jap bikes. Retired to Arizona after working for all of the Big 3 back in Michigan as a test lab tech.
Wheel Tire Vehicle Automotive tire Helmet
I doubt they'll let you run there without knee and elbow pads.
Welcome, and what Triumph are you working with?
Unit construction 70's bottom end, short stroke 750, Nourish 8 valve upper end, 40 mm flat slide carbs. Engine holds record in "A" frame at 143. Now setting it up for "M" frame.
Thanks. I look forward to the build thread I hope you're going to do.
Always interested in land speed projects, and 8 valve Triumps. Been there many times and started a build / rebuild a few
years ago but health got in the way. I'll be following your build.
1 - 6 of 6 Posts
