Have a Spyke 3-phase charging system for my shovel. It have 4 pins from the alternator. How do I test the alternator? I have 0,3 ohm between 3 off the pins and 1.4 ohm from 1 pin to the other 3. Is the one pin neutral?
Do I have to ground the neutral pin when I start the bike in open ciricuit(without regulator). I know that the alternator will put out 42 volts at 3000 rpm. I just get 3 volts out between the 3 pins and no grounding on the fourth pin.
