Not sure if this helps but grabbed from another site:
Q. Will the Dyna S work in early Panhead applications with reverse rotation distributors?
A. Yes the Dyna S works in these applications extremely well. Just remember that in these reverse rotation appplications that the front cylinder becomes the rear for ignition purposes. When using the DS6-2 single fire, simply reverse the black and white wires. With the DS6-1 dual fire, simply use the rear cylinder timing marks. Some modification to the mounting plate may be necessary for proper clearance.
