Guys,
I'm having some trouble here. I have a'57 6T and have decided to use a K2F with A/A unit instead of the distributor. In the manuals, both parts and workshop, there is no info for setting up a 6T with a mag.
So, for a '57 6T with distributor it says to set the timing at 1/32" B.T.C. (fully retarded) and valve clearance at .010"
For a same year Tiger 100 with the same cams, with valve clearance set at .010", the timing with mag is set at 3/8" B.T.D.C. fully advanced.
So, theoretically, the 6T with a mag should be set at 3/8" B.T.D.C. !
Well, I have done this over and over again with points set at .012" and timing set at 3/8" B.T.D.C. and it isn't running. I get sputtering and the pipes get hot but it just doesn't seem to want to fire up like a decently times Triumph engine should.
Stats on this particular engine:
Rebuilt top end - .080" over
Rebuilt Mag by Doug Wood
New B8HS Spark Plugs
Rebuilt 376/42 Monobloc
New plug wires
I also ensured the valve timing was correct. So, any ideas from the pre-unit guys running stock 6T cams "ramp" cams and a K2F magneto with A/A unit ? I also have a manual advance mag gear but wanted to try and get it running with the A/A gear.
Maybe I'm missing something or maybe 3/8" B.T.D.C. is incorrect?
Thanks in advance
New plug wires
Thanks in advance
