Want to put narrow glide forks on my hardtail fx frame build. Is it the sportys that got 35mm tubes and the fx got 39mm tubes?? Do the sporty forks/trees fit in the fx/flh neck?
Sportster steering stem was smaller diameter than Big Twin until 1982. With regard to diameter, the fork tubes are interchangeable between the two models.Do the sporty forks/trees fit in the fx/flh neck?
Before Harley got on board with the metric system (Japanese forks), the fork tubes were specified in inch dimensions. 33.4 mm is a "soft" conversion to metric. 33.4 mm = 1.315", 1 5/16 = 1.3125. Same way with the Wide Glide which was originally 1 5/8" (1.625") until the Japanese version came along at 41 mm, or 1.614".I have 33.4mm also....called 1.3whatever inch in the harley books. I don't think they were actually called 33.4mm until the 35mm came out.
35mm tubes only fit 35mm trees, same for 39mm.Getting a set of 80's sporty trees with the 1 inch stem. So, when I get the tubes, they can be 35mm or 39mm and will fit just fine?
First you need to know whether you have Showa or Kayaba sliders. Easy way to tell, the Showa have bolt on axle caps on both lowers, the Kayaba only on one side. As for the length, the FXS (Lowrider) and FXB (Sturgis) came with fork tubes that were 2" longer than the FX and FXE.I just picked up narrow glide trees, 35mm and 1" neck, to put on my '75 FXE build. I want 4 over tubes and need some help.
Which part number should I order?
scroll over a picture, then right click and go down to "properties", then it will show the picture address (URL).I don't know how to "Borrow" the pictures
