Been building my 74 Shovel Chopper and came to an issue on the front fork. I running a Durfee girder that measure 5 inches between the tubes. I'd like to run a disc brake plus an 80 spoke hub since I picked up an 80 spoke wheel that matches the rear. The rim is laced to a wide glide hub so I'll need to re-lace it to a narrower hub. Anyone had any luck running a disc brake on a super narrow (5 inch) front end? Anyone know of a 80 spoke hub narrow enough to run with a disc?
I know they make a drum hub that would help for clearance but they don't make it in 80 spoke config. I'm thinking I can offset the hub when I re-lace it for a little more clearance too.
Thanks in advance!
Thanks in advance!
