61 - 80 of 225 Posts
Discussion Starter · #62 ·
Looking good man, got to get rid of all that yellow though. Keep up the good work.
Thanks mr Greybeard. im working on the paint "problem"...
The engine is out of the frame!
she looks kinda sad...
Had some problem with the nut on the front pulley.. i used 3 different air driven machines before it came loose!!
fuck i was nervous!
those threads doesnt look OK to me....
luckely I had some luck also...
built a engine stand "by eye"...
close call.
more.......
Discussion Starter · #63 ·
What do you guys think of its color... a little blueish.. to hot or is that normal?
front cylinder inlet...
front cylinder exhaust...
oil oil oil oil....jesus!
rear cylinder exhaust...
also a little "damp"....
Discussion Starter · #64 ·
more new posts above....
last 2 pics....
belt...
it didnt like gas dripping on it!
atleast i got this one as a spare on long runs....
A question guys.. how the fuck do i get the cluth of the gear box??
cheers // Kenneth
You said your trams was a 5 in a four case?.... Is it a ratchet top or rotating top? I am looking at redoing my primary /starter setup (smaller starter), I already have a 1 1/2" belt... But don't want to spend $1000+ just to have a smaller type starter..
Discussion Starter · #66 ·
its a Revtech 58295...
link here...
http://www.retrocycle.com/CustomChr...iveSpeed_in_a_FourSpeed_Case_with_Kicker.html
BUT its a really tight fit between my starter and the swing arm!
PO had to grind of some meat on the starter...
Discussion Starter · #68 ·
Thanks.....it must be the BDL set up...
The progress on your bike is awesome! Giving me inspiration..
thanks! its always nice to get friendly comments!
thats the beauty with forums.... wrench/read/wrench/read
repeat :)
Discussion Starter · #70 ·
Thanks for the help Bigdawg... i thought i could do it without a puller....
(easy way)
have to fab something :)
(fun way)
im having a "wrenchtillyoufallasleepnight" to night hopefully i get the frame naked and ready for PAINT... phew getting tired on that yellow
thanks again for the input. and have a nice weekend :)
Discussion Starter · #71 ·
8 hours in the "workshop"... good music and alot of Grovsnus!!
what else can a man wish for...hehe..
Made a simple puller out of a 5 mm (0.19") stainless steel plate, drilled three 10.5 mm holes in a triangle shape with a 12 mm center hole for the "puller bolt" and a aluminium spacer between.. not harming the axel..
had to hit the center bolt with a hammer a few times and "pop" it came off!!
I really dont think this BDL setup with my gearbox was made for this bike...
just look at the machine work done on both the inside of the engine plate and on the backside of the clutch!!
motor plate...
clutch....
Really dont like the look of that starter gear!!
can it be pressed loose and turned over?
or do I have to buy a new one?
and then i saw alittle tear in the bearing plastic thingie..
I can feel alittle "play" in the bearing and it makes a "dry" sound aswell when i spinn it!
leave it or change the bearing? what would you guys do?
cheers // Kenneth
Discussion Starter · #74 · (Edited)
Sweet build ... and family. I'm thinking of a black tank with colored frame. Now I got an idea what yellow would look like. Thanks.
Thanks... im really blessed.. lovley kids and a good woman :)
im not liking the yellow... but hey everyone is different..
good luck with your scoot.
jupp... is that a problem or what are you saying? :)
I did a quick paint test...
its a smooth black enamel...
brushed it on...
close up..
i will let it cure for a couple of days and se how good it will stick to the frame...
if its good.. Just brushing the whole f...ing frame and be done with that.
if its shit.. Taking the bike apart some more and powder coat it black!
its -25 celcius to day... to cold for me!!
Change out the bearing now, before it gets you while your out enjoying the ride.....especially if it feels dry-should feel smooth and have a little resistance from the lube in the cartridge itself.
I'd run the primary the way it is-who cares if it's been machined on the plate or not, if it ran well there was good clutch action.......
I've seen worse starter gears, but yes, it can be removed and a new ring can be even soured from B.D.L.
Good luck with it's reform!
Justen
Discussion Starter · #77 ·
Thanks and thanks for helping out:)
I will change that bearing... just have to find a good source.
have a HUGE list that i have to order and its getting kinda expensive with a the little parts stacked up :(
but hey.. atleast i know all things are ok when i hit the road this summer... cant beat that!
the saga continues........
Discussion Starter · #80 · (Edited)
cabinet jesus: thats the one i found to..
i searched for 3 h last night for a reliable source :(
BDL dont show measurments on the site just there own art numbers...EHB-100
and i read some where "they" didnt recommend buying "onknown" bearings..
d-40mm D-62mm B1-12mm
(fuck what happened to the font)
whatever :)
i dont want to take the bearing out and possible destroy something in the process. and then have a hard time finding a replacement bearing..
want to know before i brake stuff that there is a way to save me from my own fuck up..
thanks for helping out.. :)
