1 - 7 of 7 Posts
I need the measurements/specs so I can weld up a motor stand for a Evo V twin....anyone? Bueller?
If no one else responds I can probably draw one up for you. I have the prints from my manulal for my 4 speed frame, but the motor mounts are the same.
Hey, thats what you could use your cracked frame for :)
I'm pulling the motor from it sometime this week. I could stop and take the time to measure and build one but I'm lazy and didn't want to do any R&D :)
All you need is two pieces of C channel, one is 2" longer than the other (actual measurement at the engine is 1.99", but your not tourqing down the engine to the stand) and two pieces of flat iron strap to weld them the correct distance apart.
Two inches is really all I needed to know huh? :) Whats the distance? thanks!
I am such a lazy fucker I just went and bought one...:p
=mike= said:
go out in the garage when you get home and measure it yourself , lazy fucker !
oh . . . here
:D
1 - 7 of 7 Posts
