Basically the bike ran great last 4 months since purchase and is a easy starter 2/3 kicks cold and 1/2 kicks when hot. I was crusining and slight backfire and bike shut down and would not start. I discovered no spark. I replaced the coil, condenser and points all with Morris parts. I have no fire and I can put my fingers on coil contacts and kick it over and feel a slight slight trickle. I have called Morris themselves(awesome people btw). They are stumped and said to send it in. I have also disconnected the kill switch pole to make sure its not grounding and still nothing. Only thing I can figure out is the magnetic demagnetized? The shaft does turn so not sheared gear on shaft. Any ideas?? I have no idea of age of magneto or magnet. The housing is the old cast and external set screws for coil. Pics of inside of housing showing the magnet. The bike is S S Sidewinder 93" Panhead with Delkron lower cases.
