No, I'm not using a solid state, so suggestions are not necessary. I'm trying to diagnose some charging issues. Seems like it's charging but barely. I have the manual and Delco Bulletin 1R-116. I haven't gotten to do a full round of testing yet. Couple things that don't make sense to me from the manual and bulletin:
-61 6V generator and a stock 6v Delco 989 regulator (the one in the pic is a spare)
- Since I have the 2 unit, I don't really see where the "Current Regulator" air gap is applicable. Input?
- Cutout relay air gap; the bulletin says to push the armature until the points just close then measure the air gap. does this mean that the air gap should be 0 when the points close, or .020" when the points close on the cutout relay?
- Voltage Regulator: if the points are closed when not running, is the Air gap supposed to be .075" with the points closed, or when the points are open?
