I have a 1964 panhead engine that I am trying to mate up to a 1983 4 spd rotary top transmission. The mainshaft in the trans currently is 12.5 inches long. I know that I will need a shorter mainshaft for the transmission (11.75"). Can I buy an 11.75" mainshaft and install it in my transmission?
The engine I have has been worked over a bit by the previous couple of owners, it has some valve train work done along with STD dual plug heads etc. As far as the bottom end I have no idea if it is stock or not. I had someone tell me the other day that you can get longer or shorter crankshafts to match up with the transmission mainshaft, is this true? If so what measurement can I check to make sure that my engine is of stock configuration.
I just want to make sure I don't have to spend more than necessary to get things right.
Thanks in advance.
Thanks in advance.
