I've installed my mag and set points gap to start to open when flywheel timing mark is visible center of the view hole. Carb is newly rebuilt bendix idle jet set 1 1/2 turns out from bottom. Have checked pushrod adjustments, they are good. Have checked for mag spark, I have spark. Brand new spark plugs set at .20. Been kicking for two days, getting an occasional pop. Nothing else. MY QUESTION: will the flywheel timing mark show up on another stroke than compression? I set the mark by feeling compression with my thumb over front cylinder spark plug hole, then bumping motor till mark came into view. All thoughts and info are greatly appreciated. Thanks.
