1 - 9 of 9 Posts
I have a cam cover that is smooth, cast in baffle plate and a casting # of 25217-40 , the outside oil line hole appears it was welded up before chrome , but its hard to tell , what is this cam cover?
Premium Member
Not all had ribs, just the pans did, the 40 was used on the pans but wasnt drilled for the outside oiler and had the ribs as the 40 knuck didnt.....Roach.
(Some one modifide it for a pan with inside oiling)
Roach , i cant make heads or tails of your post
Im not sure what year this cover is ,
36-39 HAD SMOOTH OUTSIDE OILER
40-47 RIBBED OUTSIDE OILER
47-54 4 RIB OR 8 RIB (CANT REMEMBER)
54-62? 4 FIN OR 8 FIN AGAIN NOT SURE WHICH WAY
63-65 SMOOTH OUTSIDE OILER
66-69 SMOOTH NO OILER PORT .
I CANT FIGURE OUT IF THIS IS A KNUCK , LATE PAN OR SHOVEL COVER, ANY ONE THAT CAN HELP LET ME KNOW
Those numbers are for a 4 rib cover. From 54-57 and on. They are for a Panhead. People would file or grind the ribs down and make them smooth. I have one completely smoothed and chromed and another with the two bottom ribs smoothed. Why? I don't know. Francisco
According to my books:
1936-39 = #584-36 #25216-36 (smooth)
1940-47 = #97-403 with words ALCOA (8 ribs)
1948-53 = #584-48(new 25216-48) #97-403 (8 ribs)
1954-64 = 4 ribs
-1954-57 #25216-54 and #25217-40
-1958-62 #25216-58
-1963-64 #25216-63
-1965 It should be the same as 66-69, but with an oil passage.Not sure
-1966-69 #25218 65 (smooth) This I'm not sure, I had to look at my 69
cam cover.
there are many variations from year to year. FG
1 - 9 of 9 Posts
